Ban wrote...
The buffer has the advantage that all 3 terminals of the input
transistors are at the same AC-potential, because the collectors
go to the output, thus a really wide bandwidth can be achieved.
That's an attractive aspect of this circuit. IRRC, I first saw
that cute trick in an NSC note in the late 60s.
I agree with Win, those are high-voltage parts good for +/-150V
not +/-10V. Siemens also makes some dual RF NPN and PNP with high
bandwidth, but I do not know if the supply voltage is sufficient.
Let's evaluate the scene a bit. 10V into 100 ohms is 100mA, rising
to 250mA and 3.1W if 12.5V via 50-ohms into an output short. The
transistor output-stage maximum power dissipation occurs for say
7.5V out (at the 50-ohm resistor input) at 150mA into low Z load,
for 1.1W at DC. Two sot-223 parts as shown may be fine, but three
would be a bit safer.
It'd be more interesting if the amplifier were spec'd for +/-10V
matched-impedance output into a 50-ohm load. We'd set it up for
a gain of 2x, with +/-20V output and at least +/-25V supplies.
.. ---+---+---------------+----+----+----+----- +25
.. | | 10mA | | | |
.. (I) (I) | | | |
.. 20mA | | _ |/ |/ |/ |/
.. | +---------U---|----|-----|----| fzt2222a
.. | | bead |> |> |> |>
.. fzt2222a | | | | | |
.. |/ | \| | .-. .-. .-. .-. 4.7
.. 249 | | | | 499 | | | | 50, 6W
.. o-/\/\--+ | | +--+-/\/\--+----+----+----+--/\/\---o
.. | ,-)-+---, | .-. 499 .-. .-. .-. .-. 4.7
.. fzt2907a | | gnd | | | |
.. | | _ |< |< |< |<
.. | +---------U---|----|----|----| fzt2907a
.. 20mA | | bead |\ |\ |\ |\
.. (I) (I) | | | |
.. | | 10mA | | | |
.. ---+-----+---------------+----+----+----+---- -25
The 60V Vcbo rating of the fzt2222a and fzt2907a would suffice.
One could run the input-pair current sources at 20mA and the
collector sources at 10mA, to insure enough available current
to drive the output emitter-follower transistors at full load.
The 20mA current sources could be made from two BJTs, so I get
a total transistor count of 22. The PCB would run rather hot.
Hmm, what does spice tell us about this circuit's performance?
You can use 2n2222 and 2n2907 models, they're the same dies.
