Steve
I have been buying #00, #0 and #1 battery cable, (the tinned marine grade
with the fine strands) and the proper lugs. However, my crimping tool will
only do up to #4 gage.
I've tried soldering with my 150 watt soldering iron and as others have
worned, the solder wicks up into the strands, making it to stiff.
These stiff ends are hard on the electrical terminals that they attach to.
I want to redo about a dozen lugs that I have concerns about.
How do all the rest of you crimp or swedge these lugs??
I've seen a tool that is used by the guys building DIY electric cars and off
grid elect systems. These were just a steel saddle that the lug/cable end
rest in and a crimping die is driven down over the open side. They were
using a heavy hammer for the force and that give me some concern (lack of
control, etc.).
I've seen some professional tools in the electrical supply catalogs but they
are pretty expensive for doing a dozen cable ends. (several hundred
dollars).
I'm thinking there should be some kinda die similar to that used for
NicoPress swedge rigging sleeves. (come to think of it, I have one and I may
try a test and see if it would work)
Or perhaps the marine suppliers?? But, then I already have purchased, mail
order, all of my cable. Not sure they would do it for me..
Steve
s/v Good Intentions
control, etc.).
dollars).
Steve
s/v Good Intentions
