OK. So maybe it's not figured out yet then. I'm certainly still open to suggestions.
Dorke: the board has its own 3.3 regulator, so 4.6v (5v @ 92%) is still sufficient there. Ripple & noise is what I'm most concerned about here.
I understand a substantial cap (bigger the better, yeah?) will filter out a lot of the ripple, but I'm less clear on how how to reduce noise.
Well you see,
You do need to totally specify the requirements of the P.S ,
otherwise the solution you will get to will be far from optimal in terms of cost/space/efficiency/reliability/performance etc.
So Lets start from the beginning,shall we?
1. What is it "driving"?
(as you now say,
the voltage is converted to 3.3V by a regulator,which one?,
any other like this?).
2. What is the min and max voltage swing allowed?
3. What is the current you need(min and max?
4 .What is the space you have for it (LxWxH).
5. What is the noise and ripple levels allowed?
6. Any safety regulations requirements?
7. Heat dissipation issues?
