Martin Riddle
Gary Walters said:Obsolete data controller from defunct company uses this Philips
ucontroller.
Units are failing and customer has the option of either throwing out
all his
infrastructure when these units fail and spending $$$$ to replace
everything,
or burning new controller ICs as units fail.
<http://www.datasheetcatalog.org/datasheet/philips/P87C750EBPN.pdf>
It looks like the P87C750 comes with a 16-byte encryption table,
optionally
used to encrypt the contents of program memory.
The only way, it seems, to know if the memory contents has been
encrypted is
to read the contents and see if it contains legible code.
Is there another means to know if the memory contents have been
encrypted?
Thanks.
Gary, I have a DS-750 dev kit from Ceibo. It has 2 87C750's
<http://ceibo.com/eng/pdf/ds750.pdf>
Its dos or win98 based. It will read or write the devices.
If you want to give it a shot let me know.
Cheers
