Hi all
I am trying to control a Ryobi cordless, rechargeable screwdriver, using an Arduino to make it reverse and stop, using two relays. The screwdriver has, I think, a Nimh 4.8V battery from which I am also powering the Arduino circuit and two relays.
Trouble is that when the Arduino switches on the screwdriver motor, the voltage dives from 4.9 to 4.3 V, browning out the Arduino and resetting it.
My son suggests using a LM317 voltage regulator and running the Arduino at say 3.5V, which voltage it can operating at, while running at 8MHz. That way, when the voltage droops, the Arduino will not be shocked. Will this work?
And do you have any other suggestions as to how to run micro's and motors off the same battery?
I have tried using a big capacitor across the Arduino's power pins, but this does not help.
