How to modify 20V 3.5Am to 13V 1Am
bigdaddy
I have Dell Model AA20031 Power Supply for Dell Laptop and I like to
reduce it to 13V, 1Am so I can use it on my Canon BJC-250. I have
opened the pack and I like to know how to do it. Thanks
petrus bitbyter
Use an LM317 or LM317K on a heatsink to get rid of the 7W it dissipates.
You'll need some resistors to set the output voltage and some capacitors to
keep it stable. See the datasheet for it.
petrus bitbyter
bigdaddy
petrus bitbyter
Thanks very much for your help. But I need all in detail, as I am a
newbie in electronics. Thanks
petrus bitbyter
Hmm... Can't make a ten page illustrated fool proof design description.
Besides it has been done already. Look at:
http://www.velleman.be/downloads/0/illustrated/illustrated_assembly_manual_k1823.pdf
You will not need the diodes (D1..D4) and the big elco (C4) but you need to
add a heatsink to the LM317 to prevent overheating. Keep in mind that the
metal flange has been connected to the output. In spite of this description
you will need the datasheet to find out how to connect the LM317.
petrus bitbyter
James Thompson
to add a heatsink to the LM317 to prevent overheating. Keep in mind that
the metal flange has been connected to the output. In spite of this
description you will need the datasheet to find out how to connect the
LM317.
petrus bitbyter
As was previously said, google diy power supply, and search for the
appropriate circuit..
bigdaddy
Perhaps I did not make myself clear. I already have regulated supply
of 20V DC in the shape of Dell Power Pack. I want to reduce its
supply of 20V to 13V with a 1 Am. Would it make any difference if I
have excess of 1 Am, when the demand if 1Am ? Thanks
Chris
Your Dell power Pack has the capability of providing 20V at _up to_ 3.5
amps. The 3.5 amps is a _maximum_. Your Dell almost never requires
that much current, and sometimes much less (e.g. while it's in energy
saver mode, with the HD and display turned off).
Your power supply is perfectly happy supplying exactly 20V at much less
than 3.5A too, so if you only need 1 amp, or even less, that's OK.
Some switching power supplies require a minimum load, but laptop
supplies are made to be hot plugged, and so your Power Pack will
operate well even with zero current output.
The advice given above by Petrus was good. The Velleman kit (with a
heat sink for the LM317) is a practically foolproof way to get where
you want to go. Also, the instruction sheet assumes you're a newbie,
and relies on pictures rather than text to get ideas across. It's a
winner -- go for it.
Hope this answers your question.
Good luck
Chris
E
ehsjr
Get the Vellman kit.
If you *must* "roll your own" ...
Here's a "picture".
+-----------------------> Gnd To Canon BJC-250 (-)
| -Power Supply+
+---|2200 R|---+---|-AA20031+|---+
| | o | |
| |______| |
| /______/| |
| |LM317 |/ |
+---|240ohm|--+------------------------> 12.7V To Canon BJC-250 +
With the 240 and 2200 resistors shown, you'll be within
..3 volts of target (13) per the computation. If you want
to get 13 volts exactly, add a 56 ohm resistor in series
with the 2200 ohm resistor. You do not need any capacitors
as shown on the datasheet if you keep the LM317 relatively
close to the power supply. You must mount the LM317 on a
good heatsink.
Ed
