How to measure the settling time for a differential opamp with a load of 10pF?
Mac
Qns as above.
Thx
If you can't be bothered to write out the question in the body, why should
anyone bother to tell you how to do it?
The settling time is the time it takes for a step waveform to get within a
particular percentage of its final falue.
Mac
DarkMatter
Oscilloscope.
No. Digital Storage Oscilloscope.
Or at least a scope that leaves the last triggered trace up on the
screen. It is a very short event, with that load.
See definitions for the term "Critical Damping".
DarkMatter
Said the retarded troll ****.
He didn't want a definition of what settling time is, dipass. He
asked how to observe and characterize it.
Roger Lascelles
Ground one of the differential inputs and apply a squarewave signal to other
input. Look at the output on the CRO and see how long it takes transitions
settle as close as you require to step value.
Then swap inputs and repeat check.
Then connect both inputs to the squarewave source and see how common mode
rejection handles the step. Of course, you application may only require
common mode rejection of DC or low frequencies.
Roger
John Larkin
Are you assuming you only get one chance to make the measurement?
Around here, we use pulse generators that *repeat* periodically.
To really resolve settling to fraction-percent levels, a Tek 7A13
differential comparator plugin is excellent, prefereably plugged into
a nice analog 7000-series mainframe. Adjust reprate for a nice image.
John
John Larkin
Oscilloscope.
John
John Woodgate
I read in sci.electronics.design that John Larkin <jjlarkin@highlandSNIP
techTHISnologyPLEASE.com> wrote (in <uoprtvcvq9bhl0fi3dr95fr0s5v1ret6nf@
4ax.com>) about 'How to measure the settling time for a differential
opamp with a load of 10pF?', on Mon, 15 Dec 2003:
Reprate is what radical centrists do. No way to create a nice image.
K
Keith R. Williams
Wpuld you stick around with DimBulb experimenting on you?
Those would be fully-automatic pulse generators? DO you need a
license for these things? Does Slowman know these are legal?
Oldies, but goodies. I remember staring at my first 7904, some
thirty years ago. Amazing beasties. ...and I couldn't find the
*ON* switch (a *large* bat-handle right in front of my eyes
d'oh!).
John Larkin
Good point. DampMatter can be, well, unsettling.
Actually, we prefer the five-speed manual overdrive model. This gives
superior control and better cornering.
DO you need a
They are not EC compliant, if that's what you mean.
d'oh!).
Dirt cheap on ebay these days.
John
DarkMatter
No digital storage needed, Dimbulb.
For a single pulse.. Yes. Must be captured, not just guessed at.
You overshot, and are reflecting noise ringing, you should be
critically damped.
DarkMatter
Don't you mean that it is what body builders do?
Mac
anyone bother to tell you how to do it? [snip]
I've never heard (or seen) the term "dipass" before. And the OP didn't say
anything about "observing" or "characterizing."
Anyway, Once one knows what settling time is, measuring it is easy. If the
OP knows what settling time is, but can't figure out how to measure it,
then he shouldn't be cross-posting to sci.electronics.design.
Mac
John Woodgate
I read in sci.electronics.design that DarkMatter <DarkMatter@thebaratthe
endoftheuniverse.org> wrote (in <hk3ttv4gp5vc98h2mft9ao0in6s4jovshq@4ax.
com>) about 'How to measure the settling time for a differential opamp
No. Sometimes it's spelt with a hyphen ' re-prate'.
The problem with Sloman's Theory of Deadpan Comedy is that people don't
even see there's a joke there.
DarkMatter
Read the title of the post again, dufus, I am not responsible for
your poorly developed vocabulary.
To measure:
"the dimensions, capacity, or amount of something ascertained by
measuring"
If that isn't "observe, and characterize" then the school you went
to needs to shoot you.
Observe.. Measure.
Characterize... determine settling time... through observation.
Doh! Gettinzeclue.
