la-la said:
how to make a crystal /ceramic oscilator for a specified frequency in
kHz range ?
The speed of sound in quartz is (depending on shear vs. compression
wave)
400 to 600 m/second; so a quartz slab resonant at 3.579 MHz is a tenth
of
a millimeter thick. Those (AT cut typically) are mass-produced for
television
sets, and are inexpensive and available off the shelf.
At 15 kHz, an AT quartz resonator would need to be (in size) about 200
times that,
2 cm thick (and broader than it is thick, so it'd be a Frisbee-sized
disk). They don't
make those, as far as I know. Normal mortals couldn't afford one.
For wristwatches, a tuning-fork is used, and one can micromachine it
from quartz
and laser-trim its weighted tines for frequency and couple to it using
the quartz
material's piezoelectric properties. Those are mechanical oscillators
with
non-quartz parts, but they still get called 'quartz resonators'. The
common
frequencies are mass-produced, and that means 32.000 kHz and 32.768
are available, but not the lower frequencies you ask about.
The typical resonators used for 5 kHz are tuning forks and guitar
strings, or they
aren't mechanical at all...
