Platforms
Content
henzbelmont, in your case I would hang a thermometer on a suitable wall.
Thanks Steve. Wonder why I hadnt thought of that.
The infrared sensor to be installed in the processing zone to monitor the temperature of removable hot metallic body. And the temperature reader/display to be installed on the control panel.
Surely the "removable body" has to be mounted on something or has some means of afixing a temperature probe?
Well, I had that idea. But, I wonder if a thermocouple fixed on the mounting of the hot body (instead of direct contact with the body) can give correct results. It is understood that the body and the mounting will have temperature difference.
I have no idea about the K-type thermocouple, whether simple touching of the probe will give correct results.
