You want to transmit on a band that's used for cellular communication? That would be illegal. Or do you want to transmit it through a cellsite? Because that's an option; you can get GSM data modems that accept a SIM card, like a cellphone, and can transmit and receive data on the internet, if they're in a location that has cellular coverage.
You haven't told us anything about the purpose of the project or what you want to do with the image at the other end.
If you have a transmitter and receiver on the same device, the receiver will receive the transmission extremely clearly because there is no loss of signal from the transmitter, so you won't get a meaningful signal-to-noise measurement.
Signal-to-noise measurement at the receiving end is what's important. (And generally, protocols are bidirectional, so both ends are receiving some of the time.)
Assuming you have transmission in both directions, each end can estimate the quality of the link between the two by looking at its own received SNR, because the effects that cause signal degradation will generally cause the same amount of degradation in each direction. So if one end receives a signal at 8 dB SNR, it can assume that its own transmissions will be received by the other end at around that SNR as well. I'm no expert on this; others may be able to elaborate.
