Lamps do fail both "open" and "shorted". Usually shorted blows a fuse
or trips a breaker somewhere...
I wish. Many moons ago, at LeRC, I designed and had built some
16-channel cards for a Q-Bus system; to drive T1_3/4 lamps in those
rectangular push switches. You had 4 lamps per switch and with gels
could "change color" by powering different lamps.
These were driven by a Falcon on the backplane; I think via a DRV-11
card. I was issued a hard requirement that the lamps had a minimum
on-time sufficient to be seen; say 1-5 seconds, as some feared the
sw would blink them on and off so fast that...
I used #330 lamps. I designed a card with decoding and ....NE555's...
as both the timers and drivers.
Since there were 32 cards per system x 16 lamps/card; it turned out
I needed a fair sized supply, but so what...I found a unit with
SCR-regulation of the primary side -- far cheaper than direct DC
regulation and more than adequate.
Buying the 555's was an issue. You Shall Not Procure that which is
in the stockroom; Get It There. Stockroom err.. blew a fuse...
themselves and accused me of "hoarding" when I req'ed 5000 NE555's.
That was many times the predicted annual demand for the Lab. They
refused. Procurement said "You Shall Not..." again. I finally got
them from DSA in Columbus...learning that if you buy^H^H^H trade
virtual money for real things but WITHIN the USGovt, that's NOT
"procurement" no matter how big...[Later, moi, a lowly GS4, signed
a PR for a $0.5E6 order of custom graphics terminals, proving it's
easier to spend more than less...]
Finally, we got everything built and the chief tech & I went to the
test bed, in the big computer room. Mounted the backplane, ps's,
switch array, connected the Falcon to the PDP-34 that drove it, and
started it up. All went well until I turned on the 50A lamp power
supply.
WACK went the chassis... pieces spit out the fan toward us, and a
significant puff of smoke exited the cabinet and went toward the
smoke detector above. I recall thinking "Let's see... Set off two
non-adjacent smoke detectors and the sprinkler system will rupture
the air/H2O isolation disk. There are about 150 people who WILL be
PO'ed when the EVAC alarm goes off. Plant Protection [ie fire dept]
will be here in about 90 seconds. Shit, the paperwork this will
take.."
The good news is the 2 Zillion CFM HVAC system that kept the resident
370-3033, Cray 1, DG Nova, 40-odd PDP-ll's and several VAXi cool
had just-below-the-ceiling air currents that broke up the cloud and
spread it around....no horns...
We powered down and looked inside. About a dozen to 18 NE555's were
in pieces or just plain gone. It turned out that some high percentage
of lamps were hair-shorted. We rigged up a direct-to-lamps power
cable and tested each batch that way; the many hundreds of instantaneous
amps from that 50A supply made sure none were REALLY shorted, at
least not for long.
But I went back and justified my decision. The 555's were something like
27c each from DSA, and even if I'd had room for picofuses, they were
over a dollar fifty each.
