Carlo
I'm working on a traffic control device where lives could be on stake
when our device fails. I have to switch 230Vac for a 20W lamp such
that I can ensure the current flow will be broken when the logic says
so. How to accomplish this?
I have studied the following options, but no definite solution found.
1) Relay. Not fail safe because of possible contact welding.
2) Fail Safe Relay. How to use these? As far as I can tell they are
not really fail safe, but you get a control signal which tells you the
contact is working correctly. Using additional circuitry this control
signal can be used to control another power switch (which might fail
for the same reason).
3) Solid state relay. Most designs are not fail safe and create a
closed circuit on failure. The only fail safe device I found is the
Omron G3MC. According to my supplier this device is out of production.
My national Omron office is doing a system upgrade and can't access
their computers....
Are there other options for a fail safe power switch that I am
overlooking? Other fail safe Solid State relays?
their computers....
