K
ken
Have a Hard Drive (HD) that makes a very loose contact with the power
connector. At first thought it was dead but changed PCs and it is
OK. Also some other Good HDs have start up problems with this PCs
power connector.
Normally when the HD does not show in the BIOS on startup I shut down
the PC, then I move the power connector and restarted the PC and the
HD starts OK.
Am wondering if can wiggle the power connector while the PC is going
or can this damage either the HD or power supply?
Am also wondering if anyone else has had this problem and what was
done to solve it?
Should mention that the PC with this problem is inexpensive so am
wondering if the contacts are corroded so the resistance is increased
or if the contacts have just become loose from changing HDs? Maybe
both?
Ken
power connector.
HD starts OK.
done to solve it?
both?
Ken
