Hey All,
Thanks for all the replies... Yes, I was vague. It's for a project very similar to the "Balanced signals" which eliminates the noise from a signal by (as I understand it) 1) inverting the signal, 2) transfering the original signal along with the inverted signal, 3) re-inverting the inverted signal back, and adding them together to get rid of the noise aquired during transmission (for those who dont know about balanced signals). So, my question is:
Can you invert a signal such that it is an exact opposite of the original, or does the inversion distort the original signal so that if it were re-inverted it would have lost something? It seems invertion would have to have some affect on the signal, and if so, can the original signal be changed to match it (so it would be the mirror image of the inverted signal? Yes, the signal happens to be 110v ac single phase current (house current). I'm not interested in a DC to AC inverter,... just ac 110 to ac 110. (but inverted). And Yes, Steve, the two 110 legs in a house ARE inverted with respect to each other. And getting back to my question, IF you were to invert the one leg, would it be just like the other leg, or would the inverted also change something else, like it had gone through a resistor perhaps? Thanks for all your replies, David K
