K
Kevin Aylward
Phil said:"Kevin Aylward"
** Obvious to anyone who is not mentally ill - like YOU are.
** Shame about the ** 500 kohm** volume pot on most electric guitars
and the 1 Mohm resistor on the J-FET gate.
The high source impedance of the guitar PU does NOT attenuate their
thermal noise like a 5 k ohms resistor !!
DAMN SHAME what happens when the guitar's volume pot is turned down
slightly from its max position - instantly making the source
impedance very high and resistive ( 100 -200 kohms typical).
Kinda swamps the tiny noise contribution of a 4.7 k series resistor !!
I never have my volume pots at any setting other than full up. Its the
professional way to play. It keeps the S/N at its best. It shunts the 1M
input amplifier resister, keeps the signal at its highest level and it
reduces the effect of cable capacitance. I use a volume pedal in the
insert point of the amp. Guitar volumes are only for those that don't
know how to their equipment to best effect.
If you are using the internal distortion of an amp, guitar volumes are
simply useless. One needs to set the amount of distortion and volume
independently. You can only do this after the distortion stage.
Aylward is totally INSANE .
Standard ASININE performance for someone who has bi-polar disorder
and ASD.
** Not at all.
** Have built over 100 SS guitar amps (my own design & with J-FET
inputs) and serviced around 6000 valve and SS guitar amps over the
last 36 years.
Oh... build and repair...so you are a repair tech with delusions of
grandeur.
Seen, played and repaired most types of electric guitar too - Les
Pauls, SGs, Strats, Teles etc.
** Absolutely for sure.
Most electric guitar PUs in common use DO generate lots of buzz and
hum.
Again, I disagree. If the guitar is a modest distance away from the amp,
a decent humbucker does not pick up any significant hum. Sure, at very
high distortion gains, hum is magnified a lot, but so is the thermal and
shot noise.
Kevin Aylward B.Sc.
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
"There are none more ignorant and useless,than they that seek answers
on their knees, with their eyes closed"
