Phil said:
"blisca"
** The best input in terms of s/n ratio ( background hiss for
electric guitars is obtained with J-FET - types like the 2N5459,
2N5457 or 2SK30A are suitable.
Well, the 2n5459 has around 3nv/rthz at 1k, more at lower frequency, so
it is a poor choice compared to a 2sk162, which is around 0.6nV/sqrthz
(26 ohms noise resistance).
Use them as either a source follower or with the drain as the output
with gain set to around 3 to 5 times.
The input load should be 1 Mohm or greater with a series resistor of
4.7 kohms - resistor type does NOT matter here.
I wouldn't use more than a 1k series resister.
A typical pickup might be around 5k resistance, so where extraneous
noise happens to be low, a 5k extra resistance is around sqrt(2) more
noise than ideal. No point in adding noise when not necessary.
However, most guitar PUs produce significant buzzing and humming
noise which makes low noise pre-amps a waste of effort.
Not really. Do you actually have an amp and guitar? I do, in fact
several, and I just pluged one in to test, and I am afraid that your
information is a tad erroneous.
For the purposes of this test it was my Marshal AVT150 (the world leader
in guitar amp sales), and my John Connelly Maple Neck Les Paul, lovely
smooth neck indeed. The amp set clean, has very low noise indeed, you
have to be right up to the speaker to hear the noise. On inserting the
jack into and out of the guitar it is abundantly clear that the amp is
the dominant noise source. There is very little change in noise level,
well so long as the guitar is away from the amp by a couple of feet so
as to not pick up the transformer field.
I could of course try the same experiment with my Gibson Explorer, and
my Fender Twin, but the results will be the same.
Kevin Aylward B.Sc.
[email protected]
http://www.blonddee.co.uk
"There are none more ignorant and useless,than they that seek answers
on their knees, with their eyes closed"
