Jamie
I have this 2011 Grand Cherokee with keyless entry and ignition system.
It works great and makes it easy to not need to get my keys out of my
packet however, this last saturday while shopping, I came out in the lot
to get back in my car and I couldn't open the door with out using the
emergency key in the FOB. I did that however, the instructions in the
printed user manual instructs you to use this emergency key for both
getting in the car and starting it as well, that just isn't so![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
After whipping out my phone which has the printed PDF full manual on
it, It words it a lot differently, clearly indicating that you need to
use the tip of the FOB as the key with the emergency key inserted with
in the FOB as normal. WIth that, I was able to start the Jeep and be on
my way..
But this is the issue, I have owned this Jeep for less than a year, I
bought it new obviously. I checked the manual for the cell type which
indicates using a CR2023 button cell, ok. Well, I had some Cr2032 cells
around which last longer. So I commence to opening the FOB and what I
find in there is, a "CR2032" already installed? Well, why does the
manual indicate using a "CR2023" with no other options and that is not
what they are installing in there?
Shouldn't that cell last much longer than 10 months of use?
I did some online research and it seems that this device likes to
transmits a lot when ever I am in the car using the ACC mode, which I do
a lot, and maybe even when the car is operating. I don't know if this
contributes to the drain or not?
I will say this however, there is a very neat system in there, it
appears that real hardware key must be inserted in the FOB before the
FOB will work as a key itself. By looking at it, the tip of the real
key is acting as a transmittion line or E-line because there is a coil
that is wrapped around the key up on the neck of it inside. I mean, the
coil is hollow to allow the key to slide through it. I know the FOB does
not work with out the real key inserted in it. Just an interesting
observation.
I just wonder what I'll do when the transponder in the car decides to
stop working!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Jamie
my way..
observation.
stop working!
Jamie
