Or more aptly, how can I modify them to always be on?
More explanation:
Take an electronic device like a TV or a receiver. Most likely it has a momentary power button switch. By this I mean when you press the button in and then remove your finger, the button returns to it's initial position.
By magic unknown to me
just by making contact for a brief period of time, the device stays on. Further amazing is the devices ability to be able to then shut itself back off if pressed again.
I do not know or understand how this is possible - although I want to be clear *I fully understand how a momentary push button switch works* (via push-to-make, or push-to-break). What I really want to know is the magic behind the button.
I am doing a project (building an arcade cabinet) where I have several devices that I want to plug into a power strip. Then I want to be able to turn on that one power switch and have everything (including a computer, TV, and receiver) all turn on at once.
To do this I would like to remove the on/off functionality and have devices always be on. Furthermore I'd like to understand what the "magic" is and understand how these devices are working.
Additional info: I've noticed with my TV if I hold the power button down (via tape or something) and then plug it in, it turns on. After unplugging it and then plugging it back it, it again turns on. So this perhaps might be an easy way to mod the TV but I'm nervous about constantly shorting a switch that was designed to make contact for a very short period. Is there a chance I would fry an electrical component doing this?
I've also noticed with my receiver the behavior is not the same so I know there are different implementations behind the push button switch.
More explanation:
