How do I build a simple charger for 3 or 4 LI-Ion cells ?
I have a number of 18650 Li-Ion cells I want to use in some home-made stuff.
What I want to build is a charger for the cells. Input is 12-18 V. Preferably something that can be built-in.
I need overcharging protection, deep discharge protection I can do without..
Any suggestions ?
Do you want to use the batteries single or in combination (parallel or serial connection)?
For single use, you can buy inexpensive charger modules (example) that operate from 5 V, so you'll need an additional step-down module (also not expensive. Example) to create the 5 V from 12 V ... 18 V. These charger module are used to build a 5 V power bank from the Li-Ion battery.
For a parallel connection of the batteries the same setup can be used. But paralleling Li-Ion batteries bears a certain risk, read e.g. here.
For a series connection you will need a charger with charge balancing to ensure long life of the battery pack.
