I use a mobility scooter with two 24V AGM sealed lead acid batteries which I charge with a 24V 5amp SLA charger via XLR charging port. The batteries were not recharging and I discovered the 12 year old charger had died. Got a new charger and it was not charging either. Thought the new charger was defective, tried another new one, still not charging. I was told the batteries must be so low that the charger would not operate, and since the batteries were getting old, I had two new batteries installed, and they will not recharge. My research leads me to believe, since the batteries and charger are new and all connections to the batteries are intact with no signs of cable damage, that the XLR port probably needs to be replaced. No one locally will touch it, and the scooter is a 12 year old import from Israel, the replacement port and wiring harness being in limited supply and rather costly. I know how to remove and replace the port/wiring, but I really would like to determine if it is the problem before wasting the money. Is there a simple test with multi-meter I can do to see if it is bad? Thanks so much for your help.
Platforms
Content
