How can I switch 100 Amps at VERY low voltage?
Hi all,
After a half dozen re-writes, I realize I may be asking
the impossible, but here goes...
What I need to do is supply 100 ADC to a .001 ohm load
and reverse the polarity to this load every four seconds.
I'm seeking a (least expensive) solution that can be used in
lieu of multiple relays because I believe most contactor
relays within my budget would be short-lived.
The most desirable characteristics in order of
importance are:
1) Robust design (failure intolerant situation)
2) tolerate 50% duty cycle @ 100 Amps (100% if devices
share the same case/heat sink?)
3) operate at as low a voltage as possible
4) Low thermal loss (lowest switching device saturation
voltage)
5) easily mounted device(s) to facilitate heat sinking
(i.e. TO-220 case style or chassis mountable)
6) easiest and/or most convenient drive requirements
Thus far, considerations have included; 4 3PST contactor
relays, 2 contactor relays + 2 power sources, 4 SCR's, 2
SCR's + 2 power sources, MOSFET(s), and power
transistor(s). IGBT devices were abandoned because I could
not find one with low enough saturation voltage, and DC
SSR's due to cost.
Optional control scenarios included programming the power
source to zero current to turn off SCR's, and in the case of
relay's, additionally firing an SCR across the p/s output to
circumvent contact arcing (might not be possible if o/p
voltage is under 1 VDC?). Obviously, an additional goal is
a favorable MTBF of p/s('s) and component choice(s)... .
I have some junk box parts, consisting of used
contactors that will support 100 ADC with paralleled
contacts (coils are 24VAC, high wattage...), 4 SCR's are on
order to at least try (MITSUBISHI TM200DZ-H's X2, but I
don't expect these to meet characteristic #4 above), a few
SSR's suitable for p/s input or contactor drivers, and
several large heat sinks.
Can anyone recommend alternative device(s)
(manufacturers & part numbers?!) or even a full
switching/control scenario utilizing as much of my on-hand
items as practical - that will generate the least amount of
excess heat without eating up my two used power supplies
that would cost me $4000+ each to replace if I had to do it
during a test cycle... .
Thanks in advance!!!!
Stephen Kurzban
H
Homer J Simpson
Why? An explanation would help to focus the answer.
FWIW, have you looked at magnetic blowouts?
Peter A Forbes
Albright International have motor reversing contactors with magnetic blowouts
and double-contact break on most of them.
We use their products a lot and have found them to be very reliable.
Carriage/Post might be a cost problem if you are outside the UK, but worth
looking at.
The SW180 is probably the one to look at for single pole switching, but look
through their site and see what suits you:
http://www.albright.co.uk/
Peter
E
Eeyore
Is it an inductive load ?
That makes a *big* difference.
Graham
PeteS
Graham
What rise / fall times can you tolerate? Even assuming a non-inductive
load, it's going to take some time to switch that amount of current.
Note that even a non-inductive load will still have some inductance
simply due to connectivity; very small admittedly on a good set of planes.
Cheers
PeteS
Nermal
How about mercury relays.
Four spst NO relays will work.
These relays have very good overload capabilities.
They will emit a lot of RFI when they open on an inductive load.
Resistance measurement similar to those taken with the galvanometer in a
current comparitor bridge - the system is currently missing the accessories,
one of which is a DPDT 100A high current switch. I'm designing a replacement
for it.
Please tell me more :) What is a magnetic blowout?
The biggest problem I'm seeing (besides cost) in a mechanical solution, is lack
of DPDT contact arrangement, heat generation in driving the relay coil(s), and
duty cycle.
I'll do an internet/Google search later today for "magnetic blowout", but I am
primarily interested in a solid state solution because of the potential for
mechanical failure due to the high duty cycle - thank you Mr. Simpson!
I found reference to them last night but no prices (yet) - and have the telephone
number for their U.S. distributor so I can call them tomorrow. I do not know if I
can afford their product line until then, but also, I have no idea what a "double
contact break" is either (was planning on asking them that question). Same with
the magnetic blowout (don't know what that is, didn't know to ask them, however ...
thanks).
looking at.
Peter
I would ultimately reconsider a mechanical solution if one was available in DPDT
and the specifications were favorable.
What I've been seeing, is many of the manufacturers (I've talked to so far) are
stating increased DC ratings of their lower current contactor relays. However, by
the time you get to their higher current product lines (where they would support
the 100 Amps I need, mostly with all contacts in parallel), they are actually
de-rating the contacts at DC. Not sure why.
My primary goal, cost aside, is to avoid facing a mechanical failure at an
inopportune moment - so I've been trying to focus on a robust solid state
solution. ANY solution I choose, however, must not generate too much heat (the
biggest stumbling block to a solid state solution, no?).
Does Albright offer a DPDT relay that can switch at least 100 ADC 450 times per
minute through each contact (or 4PDT at over 50 ADC per contact)? If so, do you
have any idea of the price range?
Thanks Peter - your input is appreciated!
Any :)
Yes, load is "mostly" (per your observation) non-inductive.
Thanks Pete
L
legg
Hi all,
importance are:
voltage)
SSR's due to cost.
You can get mosfets in the milli-ohm range.
Saturated switching is where these things can be used safely and
effectively in parallel. The more you use in your full bridge
arrangement, the lower the loss will be in the switch.
http://www.infineon.com/upload/Document/BSC020N025S_Rev1.0_G.pdf
With four fets per switch arm, switch loss would be half the loss in
the 1mOhm load.
A full wave bridge at this voltage level could be driven directly with
15volt logic - though you'd want to keep the change-over slow, to
allow the current to reverse without resorting to body diode paths.
RL
Jamie
Hi all,
importance are:
voltage)
SSR's due to cost.
Stephen Kurzban
Mercury Relay.
Spehro Pefhany
Hi all,
<snip>
Two 2-pole 100A mercury contactors would do the trick. IIRC, they take
longer to break than to make, but if your power supplies limit smartly
that might not be an issue (in fact, shorting might be the way to go).
They are available with 120VAC coils. I'd expect around $500 total.
Durakool is one of several makers. Good for millions of operations.
Alternatively, you could use four of something like this:
http://www.st.com/stonline/books/pdf/docs/8220.pdf $35/ea. at Digikey.
in an H-bridge configuration. You'll be burning up 90% of the PS
output in the two MOSFETs that are on at once, in this case.
The mechanical contactors will work too, but the noise might drive
anyone in close proximity mad.
Best regards,
Spehro Pefhany
Thanks for the input Nermal
Allied Electronics had a "mystery unit" listed I planned to follow
up on (SRC Devices # MSS71A12). Just did - it's very low current...
Magnecraft makes one I can parallel (WM60AA-120A) but preliminary
searches Friday indicated four of these would be out of my price
range.
Two Tyco PRD-11AG0-120 relays might work, but are more than I want
to spend (over $60 total) until I know if the SCR's I have coming
are going to work out - and - if a solid state solution would be
more reliable/cheaper, that would still be my first choice since the
Tyco unit might not stand up to the duty cycle long enough to make
it cost effective. Same with some Stancor's I just looked at ($84 -
$120 for two SPDT, 100A or 200A at Mouser).
I can spend > $50 (more than I already have!) on a solution, but if
I do, I'm hoping it would be reliable (permanent) and not run too
hot - and I prefer to avoid mechanical solutions for that price
unless there is no practical electronic one...
L
Lostgallifreyan
However, by
would support the 100 Amps I need, mostly with all contacts in
parallel), they are actually de-rating the contacts at DC. Not sure
why.
Are these parts specified for high volts (>200V) as well, i.e. switchgear
for mains supplies? If so, it could be because DC at high volts and high
amps can make an arc on breaking contact, that is hard to stop. Even with
arc supression, I think there is more contact wear with DC.
reglarnavy
You might have a look at the Kilovac APX-150 relays at www.kilovac.com.
They're now a division of Tyco. They can handle lots of current, have
very low contact resistance, and are vacuum sealed, which
significantly reduces arcing and contact damage. I think that they
might even have an inert gas in them. I worked on a project years ago
that used a similar Kilovac relay and they performed well. No idea
what they cost.
G
Gary Reichlinger
Take a look at some application notes for multi-phase buck
regulators. International Rectifier (www.irf.com) and others offer
parts for this approach. I would envision that you could use 2
regulator configurations (one for each polarity). By leaving the
ground side mosfets on during the time the other regulator array is
active, you would complete the circuit. The multiphase approach
allows the use of multiple mosfets without the need to parallel them.
Mook Johnson
Hi all,
importance are:
voltage)
How much loss can the switch have? is the supply a current source or a 0.1
V voltage source?
My first thought would be a TO-247 Mosfet H bridge with 2 - 4 0.002Rds FETs
per switch (8 to 16 total FETs.)
with 4 FETs per switch your looking at .5mohms per switch so thats .001ohms
through both the top and bottom switch in the bridge.
At 100 amps your looking at .1V of drop and 10 watts of Pd. That would mean
your source would need to provide .2V to get 100 amps through the load.
You will need to drive fets with mofet drivers located close to the FET
gates. I'd use at least 12V for hard saturatinon.
If you need lower contact resistance than 0.001 ohms you will have a
diffiult time. :(
Spehro said:
<snip>
Don't have that kind of money for the relays, especially when there is no DPDT
version (requiring the purchase of at least two..). I did look at these from
Magnicraft (sp) though.
Hmmm - missed the $35 each, spent over an hour looking these up and seeking
alternatives when the one price I found was $40.00. Very nice solution, but in
this incarnation, more than I can afford when you add up the need to purchase 4
(eight?) of them. I did see they were much higher voltage rated than I need
though - and went to the manufacturer's site to see if I could identify another
cheaper alternative device at lower voltage rating. Unfortunately, the site
stopped working and I couldn't download the spreadsheet - when all was said and
done, I came away with no alternative devices and no pricing...
Astute observation about the 90%! I am thinking with the right devices, and
several paralleled, perhaps that can be dropped down to 50% - but even at 90%
its a win over mechanical switching.
I wonder if anyone knows of a MOSFET switching device at low voltage and low
cost...
THANK YOU FOR THE HELPFUL INPUT!!!!!!!!!!!
Best,
Steve K.
P.S. I will be calling ST MicroElectronics on Monday.
