How a BJT Transistor works (base current version)
OK - where is your explanation (in words!) for the phenomenon of RE feedback - without using the fact that VBE controls Ic ?
I didn't need it.
In this model Vbe is some constant factor that, if it changes will slightly change the equilibrium point. I don't need to say that this voltage controls the transistor as a change in this will cause a current change and therefore (according to this model) change Ic.
It's a bit like me saying that V = IR and you arguing that it doesn't, because I = V/R. (I only say "a bit" because the equations are not linear and there are other variables, but for many purposes they are close enough)
I don`t intend to write such a paper. Since several decades, such a description can be found in several books and other resources.
OK, I'll do it. It seems like many who want to argue that the current method is useless are not willing to put in the effort to describe the "proper" way.
Hi Steve - I must admit that I cannot follow you: Vbe is a "constant factor"? And a voltage change across RE "will cause a current change and therefore (according to this model) change Ic." ?
Therefore, I repeat my question (see my post#17) that was not yet answered: Are you denying that Re implements current-controlled voltage feedback?
This would be in contradiction to the general feedback theory:
* A current-controlled voltage feedback increases the input resistance (example: Non-inverting opamp amplifier)
* A current-controlled current feedback reduces the input resistance (example: Inverting opamp amplifier).
Hence, it is very simple to see if we have voltage or current feedback.
As you know, a feedback resistor RE causes an input resistance increase, does it not? This clearly indicates that the voltage is the controlling quantity.
I've addressed this question on other forums, and to little avail. This issue boils down to one thing only. In order to increase ic, the signal collector current, what needs to be done? Well, obviously ie, small signal emitter current must increase. In addition ib, base current, as well as vbe, base-emitter voltage, must also increase inevitably, can't help that. So all 3 quantities, at the input, ie, vbe, and ib, all increase, and ic increases as a result.
But, if I may ask, what is the sequence of events, pecking order, chain of command? Which events directly impact ic, and which are incidental. Critics of the current control bjt model, which is the accepted model for a bjt operating at speeds well below its high frequency limit, and in the active region, insist that an increase in ie/ib must take place AFTER vbe increases. This is basically an assumption that ie & ib are "caused by" vbe.
I've attached LT Spice simulation schematic and plots. A simulation is surely not infallible. But I've tested bjt amps in the lab and obtained results similar to what these plots show. In the plots, gold traces are vbe, cyan (blue-green) is ib, gray is ic, and magenta (purple) is ie. Please pay close attention to the transitions rising and falling. For both rising and falling edges of the input signal generator, observe the responses of all 3 currents and the voltage vbe. Of particular interest is zoomed in rising edge which I've included for clarity. At roughly 50.0 nanoseconds time base, all 4 waveforms rise.At roughly 55.0 nanosec all 3 currents have settled to their steady state value. But the voltage vbe continues to rise long after the currents have settled.
The theory that vbe is controlling ib & ie, which infers control over ic as well, cannot withstand even a mild scrutiny like this plot. First of all, please remember our faithful trusted long-time reliable friend known as "Eli the ice man" He has NEVER been proved wrong. A base-emitter junction of a bjt is modeled as a hybrid pi circuit including a diffusion capacitance Cd, or Cbe. In order to increase vbe, it is mandatory that charge carriers be transported through the b-e junction in the form of emitter and base current. I leads V, so vbe changes AFTER ie and ib has charged it up.
The fact that ic/ie/ib settle to final plateau values while vbe continues to rise is proof positive that vbe is NOT the mechanism that "controls" ie/ib/ic. The signal generator frequency used here is 50 MHz. If you play with bjt parts at 1.0 MHz or below, you won't see this because the time lag is small compared to the signal period. But even with slow signal frequency if you zoom in with a high speed scope, it becomes visible. How can vbe control ic?
It is ie that controls ic, not ib. The base current does not power the load in common emitter and common base stages, so some regard ib as a "nuisance". But one can say the same for vbe as well, it does not appear at the load or provide power to it. An emitter follower however, does make use of the base current. The ib powers the load. If the signal source driving the base of an emitter follower has very limited output current drive, then it is desirable that beta be large to keep ib small. But it is worth noting that base current is not wasted, but put to good use driving the load (partially).
Comments/questions/insults welcome. Feel free to engage me. Even if you can't stand me, I will reply promptly. I'm a very approachable easy-going guy. Best regards.
Claude
P.S. Was that super bowl 49 awesome or what!
"The fact that ic/ie/ib settle to final plateau values while vbe continues to rise is proof positive that vbe is NOT the mechanism that "controls" ie/ib/ic."
"It is ie that controls ic, not ib.
Hi Claude, some time ago we already had a discussion about the same subject - and I do not want to repeat all my arguments again.
And I am happy to agree with you that "it is ie that controlsic, not ib". However, the question rises "which quantity is the cause of ie"? I couldn`t find an answer in your contribution.
Perhaps you have seen some of my arguments in favour of voltage control in this thread - unfortunately, there was not a real and serious discussion.
In contrary, one forum member was so free to consider my attempts for describing my position as "rubbish" - to me it is really funny, it seems that for some people this question is something like a religion that cannot be discussed.
In addition to my earlier presented arguments, I can mention the Early effect which clearly prooves that it is the electrical field within the base region (prop. to the voltage Vbe) that influences Ic. Finally, I like to mention that this sight is clearly supported by papers from Stanford Univ., Berkeley Univ and also the MIT. References can be provided.
LvW
LvW
The CAUSE of ie is the external signal source whose signal is inputted to the bjt amp stage, i.e. a microphone, tuner, CD player, antenna, etc. Let's say that the bjt amp in question is the 1st stage of a PA system, and Sue is singing into a mic plugged into this PA 1st stage.
The mic signal is a steady value, then Sue inflects her voice and increases the mic output. The mic diaphragm vibrates with greater amplitude. For a condenser tye of mic, charge in the electret element undergoes an increase in displacement resulting in an increased current out of the mic. Likewise the charge separation increases, which increases the mic output voltage.
But the bjt b-e junction does not respond instantly. As these increased charges propagate through the mic cable it takes finite time, ic, the bjt collector current has not increased yet. When this increased charge density arrives at the bjt b-e junction, what happens?
The holes enter the base, electrons enter the emitter. From that point they easily drift through their respective regions since holes are very mobile in the base, being the majority carrier, likewise for electrons in the emitter. The small signal b-e voltage vbe has not yet responded to this change.
When the electrons have completed their journey through the n-type emitter region (bjt device is npn), they encounter the p-type base. In this region the electrons are minority carriers and if the base were thick, most electrons recombine with base atoms and ionize them. But a bjt is made with an intentionally narrow base region so that electrons from the emitter survive the trip through the base and reach the collector with a very high percentage, 99.98% or so.
The increased density of electrons entering the base results in this increased number entering collector, increasing collector current ic. THe plots attached in my last post illustrate this. However not all electrons entering emitter make it to the collector.
The increased density of holes entering the base results in more holes recombining at the edge of the emitter region near the base, ionizing the b-e depletion region to a greater extent due to increased hole density. As a result a slight increase in the number of emitter electrons that recombine in this hole-enhanced edge of emitter region takes place.
Likewise an increase in electrons transiting through the base increases the number that recombine in the base region, ionizing that edge of the b-e depletion zone. This increase in depletion zone ionization at both edges increases the local E field and barrier potential.
The b-e voltage vbe, increases in response to increased emitter current ie density. Hoever let us remember that a very small fraction of emitter electrons get left behind at the emitter edge near base, and in the base itself. So the collector current increases immediately after emitter current increases. Since electron emission increases, so does collection, with the delay being the transit time from emitter through base to collector.
But how does vbe get charged up to the new increased value? As electrons ionize both edges of the depletion zone, the barrier potential builds up with increased charges transiting through. But for a bjt whose beta value is over 100, quite common, less that 1 electron per 100 contributes to this increased ionization and voltage increase. Thus many electrons must transit through emitter and base in order to eventually build up the depletion zone ion density to its new increased value.
The plots illustrate this. Notice how collector, base, and emitter current reach their plateaus long before vbe does the same. The increase in ie is propagated very quickly to ic, but the increase in vbe takes more time. The depletion layer gets increased by electrons/holes that recombine and that is a small fraction of the total.
It is clear that Sue the singer is what "controls ie", and clearly NOT vbe. The ic has settled on its plateau while vbe is still catching up. Then vbe keeps increasing to finally and eventually reach its plateau whereas ic has been constant for a long time.
There is no doubt that ic is controlled by ie, and ie is controlled by the signal acting as stimulus, which is Sue's microphone. Vbe cannot be the cause of ic because a cause must ALWAYS PRECEDE its effect. This is not the case. Ic stops changing while vbe continues to change. That is a no brainer.
I will clarify if necessary, but you have asked me that question before which I've answered. If you have issues w/ my treatise, please elaborate. Best regards to all.
Claude
And the rise time and voltage, sorry forgot to ask that.
Adam
Vinitial 0.00V
Von 0.10V
Tdelay 0.00 nanosec
Trise 1.0 nanosec
Tfall 1.0 nanosec
Ton 9.0 nanosec
Tperiod 20 nanosec
Series Resistance 0.10 ohm
Parallel Capacitance 1.0 pf
I hope this helps. If you wish, just message me, and I can email you the LT Spice schematic file I used. Best regards.
Claude
Hi Claude I can't see clearly enough, but why have you added so much to the math to the waveforms.
Adam
I added gain and offset to make the waveforms easier to compare side by side. LT Spice puts the 3 currents on the same scale. The base current would be very squished compared to collector & emitter currents, so I gain up the base current. But the dc offsets would also get gained up and go off the chart, so I include an offset to keep the plot in the center of the grid. Likewise for vbe.
Ok I guessed so much just checking. Please email me the sch, arouse1973@yahoo.co.uk.
Thanks Adam
"The CAUSE of ie is the external signal source whose signal is inputted to the bjt amp stage,
Hi Claude, I think we are speaking of voltages and currents , right?
1.) Why are you using such unclear terms like "signal" and "Sue the singer" ?
This does not help at all to understand your answer to my question "how is Ie controlled"?
I think, it is not correct to say that "ic is controlled by ie" - there is no control function involved, the current Ie is simply divided into two currents (Ie=Ib+Ic).
Hence, my question again: Which quantity controls (determines) the current Ie? (Your answer was: An "external signal" and/or "Sue the singer" - not very helpful.)
2.) More than that, I suppose you will not be surprised about my comments to your simulation results:
They do not convince me at all. We speak about the physical properties of the BJT - why did you simulate a complete circuit with 5 resistors and a capacitor?
I think, such a circuitry will influence and overshadow those effects we are interested in. And - why do you use Re feedback?
As you know, it is the current Ie through this resistor that determines the final voltage Vbe (with your words: the "plateau").
I think, this effect does not allow any conclusion about the timing sequence within the BJT alone!
Moreover, the collector resistance causes a corresponding change of Vce - leading to a base width modulation (Early effect) which also influences the result.
3.) Why not simulating the BJT without any external circuitry? That`s what we are interested in.
Use a fixed voltage Vce (emitter grounded) and an input step of approximately 0.65 volts at the base and watch the results. As an alternative: Use a voltage step for Vbe from 0.65 to 0.66 volts.
4.) However, in general, I am not sure if circuit simulation is the right tool to support theoretical questions - in particular when the timing of physical effects is involved.
The primary purpose of all models used in these programs is to see how this part will behave together with other parts - in particular, how it will influence the voltage and current distribution within the whole circuit. I would not rely too much upon a reliable modelling of specific physical effects inside the part.
5.) For my opinion, there are enough information available (data sheets and measurements) which could help to find the correct answer to the main question (without simulation).
To mention only some key words again: Early effect, tempco -2mV/K, Re-feedback effect, tanh-transfer for diff. amp .
Up to now, I didn`t receive any comments or counter arguments to these effects. Doesn`t a real discussion consists of questions and answers?
Regards
LvW
I am with Lvw on this, it just does not make sense with respect to the physics of a BJT. I have done a simulation and my plot shows Ie increasing with respect to Vbe increasing. You have to get the scaling right to see it because the changes are so small. Your only talking 691uV change in Vbe.
Adam
I specifically stated that Sue's voice inflection increased the mic diaphragm displacement resulting in an increase in I & V. The charge on the diaphragm is moving with increased amplitude, so I increases. Likewise for V. When the increased charges arrive at the b-e junction, I covered the sequence of events. The fact that Ie divides into 2 currents is worth examination. The ie current is the starting point where all begins. An increase in ie can only result in a likewise increase in ic as well as vbe. No way to skirt that. The ie is what absolutely determines ic.
To "prove" to us that vbe is the control quantity, you endlessly invoke "Re feedback" as support. Then you tell me my sim is invalid because of Re and other resistors. The 4 resistors set the bias point which is how amplifier stages are designed. The internal physics does not change by adding Re, Rc, Rb1, or Rb2.
Sure it allows a conclusion. The timing sequence in my plots agrees with "Eli the ice man", which has been the law since the 19th century. Eli never lied to us yet. The b-e junction has a diffusion capacitance. How can the voltage across a cap determine its own current?! Impossible. If vbe must change 1st before ie can change, what is the agent that changes vbe w/o incurring a prior change in ie? Can you answer that. How can the increased mic output cause vbe to change, then affecting an increase in ie? Impossible according to Eli, a reliable source.
Early effect is slight compared to what happens at the junction. Early effect is something you should explain and detail why it supports your position. When a bjt is stimulated with an input base current, the collector current is plotted vs. Vce. Above a Vce of around 0.6 volts, the device is in the active region, and the plot is almost, not quite, horizontal, the slight slope owing to Early effect. As Vce increases, Ic slightly increases. The"cause" f this is not vbe, at all. The b-c junction is reverse biased, so a depletion zone exists at the b-c boundary. This boundary is not anchored in a fixed location, it can change. When Vce increases, the depletion zone shifts and the base region gets narrower, the depletion zone has moved into the base region, reducing its width. The b-e junction is forward biased, and base current for the same E field must decrease. A narrower base region has less volume than the original base region, so that less hole density drifts from base to emitter. But the emitter region is not affected bu b-c junction encroachment on the base region. The emitter emission of electrons hardly changes. So we now have lower base current with about the same emitter current. Beta has increased. Ic increases with increasing Vce, but only slightly. Early is not an effect of Vbe at all.
Then do it. What changes?
Tempco? How does that "prove" vbe is in control? Semiconductors, like silicon, have a property that conduction electrons are more abundant at higher temperature. That is a silicon property having nothing to do with Vbe. Take a slab of intrinsic Si, no n or p doping, no diode junction, just raw Si, Measure resistance end to end at room temp. Now increase temp and measure R. It has gone down. There is no junction, vbe, at all, just intrinsic Si resistance and temperature. At riroom temp, the Si lattice vibrates, in quantum mechanics the mechanical energy of these vibrations consist of discrete packets called "phonons". The phonons strike the atoms and some valence electrons gain enough energy to jump into the conduction band. These are available for current conduction. When temp increases, vibrations are stronger, more phonons are colliding with atoms, giving more electrons energy to transition from valence to conduction. More electrons conducting measures as lower resistance. Vbe has nothing to do with it.
Regards
LvW
Adam
Your plot is proof positive that vbe is not in control of ie. Vbe monotonically increases, but Ie starts out increasing, then decreases while vbe increses still, then ie increases again. Vbe never changd course, but ie went up, down, then up. Proof positive vbe is not in control of ie.
Also, please attach the schematic you used to generate said plot. I'm curious about that ie changing direction thing, thanks.
Claude
Steve - really absolutely rubbish? Are you denying that Re implements current-controlled voltage feedback?
I have several years experience in teaching electronics - what do you think how students would react upon your method to explain the principle of RE feedback? (The emphasize is on "explain" !). With formulas I can do everything - I even can exchange Vin with Vout and claim that Vin is controlled by Vout.
With other words: Formulas can only describe a relation between quantities without any information about cause and effect. That`s an old wisdom.
Yes of course equations describe relationships, not cause and effect. But seriously, examine Ohm's law, V=IR. Can you truly state which quantity is the cause?! I believe I know what you're thinking, but only you can speak for yourself.
Here comes my explanation how Re feedback works:
A rising Ic (temperature, tolerances) causes a voltage drop increase across Re - and, thus, reduces VBE which acts back to Ic and reduces its increase.
As you see, it is one single sentence which can be easily understood. Rubbish?
Oversimplified, for sure. At steady state temp, we have an Ib, Ic, Ie, and Vbe. Temp in the bjt junction rises quickly, so what is the sequence of events. You claim that the Ic rise causes a rise in voltage across Re, which is putting the cart before the horse. Then you claim that Vbe decreases as a result, then Ic decreases. But seriously, how can Vbe decrease before Ie/Ib decrease. The Vbe value is locked in by the depletion zone barrier potential. To change it, we must source or sink current from said depletion zone. Vbe cannot change w/o prior current, it's a diffusion capacitance.
So what happens with Re feedback? Steady state is established, and say the bjt suddenly heats up. What happens to Ib/Ie/Vbe/Ic as a result, and most importance - sequence of events. The key here is to note that the base side is driven by a CVS, constant voltage source. This CVS is presumed good, low impedance, and can maintain a fixed voltage under any conditions present.
What determines Ib/Ie? The CVS, which we can call Vbb, sees a total Thevenin resistance of Rb, plus the b-e junction equivalent resistance r_pi, plus the emitter resistance Re times beta+1. A temp increase does not affect Rb and Re a lot, presume they are low temperature coefficient parts, and that temp change has greatest effect on bjt.
At increased temp, silicon has lower bulk resistance, more electrons/holes are available for conduction due to increased thermal lattice vibrations. The b-e junction equivalent resistance decreases with increased temp. The CVS, Vbb sees a lower Thevenin resistance, and Ib/Ie tend to increase along with Ic. But the increase in Ie results in more electrons in the emitter resistor colliding with lattice ions. A slight increase in current builds up more charges in Re and these charges have an E field that opposes that from Vbb. The voltage on Re rises. The b-e junction voltage cannot rise with this increased current, since Vbb and Kirchoff's voltage law are in play. But the Vbe is equal to Vt*ln((Ie/Ies)+1). Ies increases with temp, as does Vt. But Vt increases linearly with temp, where Ies increases greater than linear. Ies is in the denominator, so it dominates, and Vbe goes down.
But, Ie/Ic are actually a little larger than they were in steady state. Vbe is smaller, while Ib is smaller. The increase in beta means that Re is multiplied by an increased (beta+1) value and that is what Vbb sees. So Ib decreases, as does Vbe, while Ic/Ie increase. This is possible because at higher temp, beta increases substantially.
You cannot explain this feedback with Vbe alone. It is Ib, Vbe, Ie, beta, Ies, and temp.
Claude
Final remark: You have asked for some comments to your text. That´s what I have done. If it is really "rubbish" - forget it!
Hi Claude,
I will try to respond to your reply as follows (your statements in italics)::
"The ie current is the starting point where all begins. An increase in ie can only result in a likewise increase in ic as well as vbe. No way to skirt that. The ie is what absolutely determines ic."
How can a current like Ie be the „starting point“ ? I cannot follow your reasoning.
There is no current without potential difference (voltage).
Let the collector node unconnected and apply a positive base-emitter voltage (npn case). As a result, we have a current Ie=Ib - caused by Vbe - from B to E (exponential law), correct?
Now - apply some volts between C and E. What happens? The current Ie is now split into Ic and Ib. That`s all.
You simply cannot deny the role of Vbe because THIS voltage is the real starting point.
Question: Is there any reason to assume that - suddenly - Vbe should loose its control function?
EDIT: It is easy to demonstrate this behaviour with circuit simulation.
(a) Collector open, Vbe=0.67V: Ib=Ie=1mA ; (b) Vbe=0.67V, Vce=2V: Ie=Ic+Ib=1mA with Ib very small.
"The internal physics does not change by adding Re, Rc, Rb1, or Rb2."
Correct.
However, adding these elements certainly will distort the measurements/simulations which cannot be attributed to the „naked“ BJT alone.
Example: Emitter resistor Re influences Vbe as a result of the product Ie*Re. Hence, there is a control loop (output influences input) that influences the timing properties (which you were interested in).
"If vbe must change 1st before ie can change, what is the agent that changes vbe w/o incurring a prior change in ie? Can you answer that. "
I don`t understand the question. Vbe is an external voltage (bias condition) which is altered due to a signal to be amplified.
"Early effect is something you should explain and detail why it supports your position."
Let`s evaluate the characteristics Ic=f(Vce) for Ib=const. These curves are used to find the Early voltage as a measure for the slope of the various curves.
In words: We keep Ib=const and observe an Ic increase for a rising voltage Vce. And I agree to your explanation:
"When Vce increases, the depletion zone shifts and the base region gets narrower, the depletion zone has moved into the base region, reducing its width."
What is the consequence? Due to the reduction in width the electrical field strength increases and allows the current Ic to increase (more electrons can cross the depletion region).
Hence, it is the electrical field in that region that influences the current Ic. And which external quantity produces this field? Answer: The voltage Vbe.
"Tempco? How does that "prove" vbe is in control? "
The tempco of app -2mV/K tells us the following:
Rising temperatures cause an increase of the current Ic. In order to bring Ic back to its initial value (Ic=const) we must reduce the voltage Vbe by app -2mV/K.
For my opinion, this illustrates the controlling role of Vbe.
And note: This value of -2mV was verified by calculation based on charged carrier physics!
"You claim that the Ic rise causes a rise in voltage across Re, which is putting the cart before the horse. Then you claim that Vbe decreases as a result, then Ic decreases. But seriously, how can Vbe decrease before Ie/Ib decrease."
I agree with you that, in some cases, it is problematic to describe the correct timing sequence within a control loop.
However, that`s not the point - and I am sure you will not deny that Re provides feedback (and Ic stabilization).
The main point is: Re causes a drastic increase for r,in at the base node - and from feedback theory we know that such an increase occurs for voltage feedback only!
Hence, the controlling quantity is a voltage between B and E. Is this conclusion false?
______________________
Finally, let me make a statement that sounds rather simple:
If somebody knows how a simple pn diode works (exponential relation between applied voltage and resulting current), how/why can he assume that - suddenly - the pn junction between base and emitter will behave completely different? Is there any good reason for such an approach?
LvW
Claude
Hi Claude
It was the schematic you emailed which was very different from your thread schematic for some reason.Your original statement I think was Vbe still increases even though Ie has reached a steady state. It doesn't do this from looking at the plot.
Adam
Claude
It's simple the circuit you sent me has a reactive component in the CE path, a capacitor across R2. So the easiest thing to do was to insert a 100R in series with the capacitor. Got rid of the spike.
Adam
The circuit you sent me didn't have R7. Top plot without resistor and bottom plot with resistor.
