Have a strange question here, Im looking to achieve the effect of a
£300-£1300 device with a budget of only £120.
Ok im seen that there are some gass powered soldering irons by weller
that have a "hot air nozel" attachment. now I fond that they state a
temperature from 250C to 450C is achievable as it has adjustment. Now
I cant find any info on it being used for hot air soldering/
desoldering just that it is suitable for small "heat sink
applications".
weller site details:
WSTA6
"Non igniting butane gas operated soldering iron 15 W - 60 W.
Temperature is controlled by increasing and decreasing gas flow to the
tip. Heating-up time about 30 sec.The soldering tip can be replaced
with a hot blow nozzle which is sui- table for small heat shrink
applications. Reservoir in the handle gives approx. one hours use."
My question is do they mean hot air of hot air + combustion I dont
want a blow torch.
A hot air soldering station costs a hell of a lot of money and I only
need it to solder some smt parts using solder past, none of the
numerous attachments for desoldering etc required. I can check the
temperature of the output with a probe, will this little iron do the
job ?
Thanks for your time.
applications".
WSTA6
want a blow torch.
job ?
