How is possible to know where is positive and where is negative poles, on AC dont they change 50 times per second or so? (50Hz, one change per second)
Yeah, 50Hz means that it goes through a single cycle of zero up to the positive maximum, then back through zero down to the negative maximum, and back up to zero again 50 times every second.
There is no positive or negative. But somewhere on that board that voltage will be reduced and rectified and smoothed to a DC voltage.
Because this device doesn't have a transformer, the DC is probably relative to the neutral pole of the mains. That still makes it dangerous.
I think ill skip on this one.
I crap my pants when i turn it on and it make a kaboom sound.
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I don't blame you. You have just experienced a little of what it means to say that the mains is a high energy source.
It does demand respect.
but i need to learn from it
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Today i learn how to measure it the right way and to destroy it the wrong way
Even if it's not going to be repaired, you may be interested in finding out how it generates an AC rail. You should be able to trace through the circuit and find out that it (a) does something unusual with a capacitor) and (b) has the rail essentially connected to the mains.
I wouldn't recommend plastic gloves as a means of protecting yourself.
The best way is:
a) don't connect or disconnect anything while the power is applied.
b) remove the power plug, don't just switch the power off
c) even in this case, assume the power is on and try to use just one hand.
d) wear rubber or plastic soled shoes.
e) have someone else nearby just in case...
f) try to keep one hand in your pocket when power is applied.
