K
Kash
Hi
I have a Goodmans 205N TV with CP-775 board. I have moved from the UK
to Australia and unfortunately found that I could only get picture and
no proper sound when connecting my UK TV to the Australian system (UK
is PAL-I and Aust PAL-B/G).
I thought there might be a switch or something obvious that I could
replace to fix the problem so I opened up the TV and took the board
out. Unfortunately I found nothing. I then read a post somewhere else
that worked around this problem by connecting an Austrlian Video
player via a SCART to the TV. I then reconnected the board back into
the TV and switched it on. Everything started as normal except I now
get no picture. Just a blank tube. However sound plays and functions
like channel up etc all work. I can tell that I am changing channels
because there's a pauise and then static agsin
Any ideas??? One of the areas I looked at was the connector to the
back of the tube via a sucker. What's that for and can it be causing
the problem (i.e. incorrect re-connection).
Alternatively if you have a time machine ...
Cheers
Kash
Cheers
Kash
