![MICUnew.jpg MICUnew.jpg](https://makerv2.webteractive.co/forums/data/attachments/49/49554-349e546c114a3fbef171fcdfb5db43cc.jpg)
I have an MICU from a Honda Odyssey. The auto related forums don't appear to have too much more advice about what to do with this component, so I was hoping I might get some helpful guidance. Water has gotten into this component and resulted in some corrosion. I have not tried to separate what looks like many layers and before I break something, was wondering if anyone here had any suggestions/warnings about how to proceed. I sprayed some deoxit on the external corrosion, but it did not solve the issue.
Water entered by the pins above the circuit board and worked its way down to the bottom where there are pins that are corroded. I suspect there might be corrosion internal to this component that can't be seen until it is broken down more.
Thanks!
