Seb
Hello,
Tried to google but didn't quite find the info I wanted.
After reading on at the LED FAQ pages from the links in the Wikipedia
article on LEDs, I thought it should be fun to make my own LED
flashlight. Unfortunately the FAQs seem to assume more knowledge than I
have, being a non-scientist. I know how a simple circuit works and how
to solder wires together, but not much else (certainly not the peculiar
requirements of LEDs). From one of the help pages I got the impression
that you should use lower current (15 mAh, by using 130 ohm resistor)
and higher voltage than the LED's specs require.
What I still need to know but couldn't quite find out: what size LED do
I need to get approx. light of a 2xAA pocket incandescent flashlight? I
want to use yellow, maybe orange (cheaper and more user friendly than
white, OK match for incandescent even though the most common yellow is
greenish)--I know that different colors need different voltage. And is
2xAA a suitable power source? 9V? What resistor to go with those batts?
Maybe if it works out great, I'll try a "red night vision" flashlight.
Seb
Seb
