Spehro Pefhany
That sounds like it may be do-able.
BUT where does that resistance wire come from? Most heaters have a
much larger diameter nichrome wire, and i do not know where one can buy
"plain" resistive wire like that.
It comes on spools- manganin is better than nichrome, but nichrome
isn't all that bad. In a pinch, brass or stainless are pretty awful
tempco-wise, but relatively high resistance.
These guys have 25m lengths of it with Kapton insulation:-
http://www.iceoxford.com/Cryogenic-spares/Wiring.htm
If you need many pounds/kg of it, it's easy to buy.
Suggestions?
Oh, "insert" might be a bitch..one might be forced to spot-weld the
resistive wire to the existing internal wire.
And it ain't easy to pull out....
Except for cable TV coax where it seems pretty easy to pull out (esp
accidentally).. the dielectric is slippery PE, I think, and the center
wire a thick smooth solid wire. But it's awfully stiff for test prod
wire.
Best regards,
Spehro Pefhany
