PDM driver
Hi Bob K,
What you say, that I can use the Micro chip IC TC4422 that is rated at 9 amps and with 12 volts supply,I will put a Small value resistor in series with the driver supply voltage,10 ohms or less, and bypass with a large elect. capacitor This will supply voltage during the high current surge of the gates. The drain voltage on the IRFZ48 is 36 volts.What I am building is a golf cart controller. Do you think I need a Zenor diode on each gate or could I use one at the input of the drive chain?
Also what about the resistor with the fast diode, in reverse accross it ?
TNX,Fitz
