Radium
Hi:
Would a computer designed to use high-voltage [around 10,000 volts],
low-wattage [around 0.000001 watt] have any advantage over conventional
computers? In this high-volt, low-watt PC, all of the components
[motherboard, cpu, memory, video system (including the monitor), sound
system (including the speakers)] rely on the high-voltage, low-power
electricity. Speakers and monitor are purely digital and also use the
high-voltage, low-power digital electricity. Speakers do not contain
any diaphragm, instead they rely on "electrifying" the air to produce
sound. The electric current directly causes the air molecules to
vibrate and produce sound -- this makes it easy to reproduce
high-frequency sounds than using a conventional speaker.
In this system, the voltage is high but the amperage is *extremely*
low.
Thanks,
Radium
low.
Thanks,
Radium
