I would like to use a 9 volt battery to create a high voltage source. It's
been awhile since I've messed with electronic componets. But it seems like
I
need something like a 555 timer to create a series of d.c. voltage pulses so
I
can then use a transformer to step up the voltage from say 9 volts to 900
volts.
Is the 555 timer the way to go? or is there a better device to turn the dc
into
a pulsating dc to step up with a transformer?
Thanks in advance.
Robert
A little more to the point than the other replies I've seen here, you
likely will want to make a flyback-type supply, using stored magnetic
energy to generate a primary-side pulse that's a lot larger than 9
volts. Then the transformer turns ratio won't have to be astronomical
to get your 900 volts. You can make a blocking oscillator with one
transistor and a transformer, and not worry about using an IC at all,
though the regulation may not be what you want.
Note that Harbor Freight sells an "electronic fly swatter," sometimes
on sale for next to nothing, that generates a high voltage from a
couple of D cells. In fact, I see it listed for $1.99 right now...
It could be a way to get started cheap, with a circuit that works.
Can't swear to the voltage though.
Cheers,
Tom
