I am also attaching the output waveform of both HO and LO. Red waveform indicates output of HO and yellow waveform as output of LO. But the amplitude of both the signal are different. (It should be same).
I am working first time on these type of driver.
Thank you
I will certainly look into your valuable suggestion but may i know the reason for this.With these IC's the boost requires to see a load to common to work.
M.
Thank you
