Hi everyone,
I am trying to design variable synchronous buck regulator. I will change the buck output voltage by changing the duty cycle of PWM signal. For triggering, I am using Half bridge driver IR2104. There is no output signal in 'High side out' of the driver IC. But low side out is working properly.
Frequency of driving signal: 25 KHZ
minimum and maximum duty cycles of PWM driving signal : 10% AND 90%
VCC voltage = 12 Volt (Fed to IR2104 and drain of top MOSFET)
Diode used for Boot strap circuit: 1N4148
capacitor between VB and VS = 0.1 uf (Bootstrap diode)
capacitor between VCC and GND = 0.1uf
Resistor at the output of H0 and LO = 10kohm (I am NOT sure about which value to use )
NOTE: Supply voltage on the drain of the top MOSFET is fed from the same main 12V supply used to power the driver IC IR2104. Is there any problem on using same supply or it is fine to use??
PS: Please find the attachment. It contains the circuit diagram.
