Help with Pioneer DV-310 DVD Player
Hi Guys, I need some help here please!
I was fiddling around with the menu section of my DVD player and somehow got into an area where I could alter the display or video output to "progressive" as opposed to "interface" (the default setting)
In my ignorance, I thought "lets see what this does" Wham, no picture on the screen, with the TV saying "no input"
As it's a screen based menu system, I can't see to go back and restore it. Powering off and on (including unplugging) doesn't help
Is there a way of resetting the machine to default settings (or just back to "interface")
Any help would be greatly appreciated!
Hi, appears that you may have to power down the unit, hold the STOP button while applying power again. Screen should come back.
This is a factory reset.
Hope it works..
Martin.
EDIT; Page 12 of the user manual has another way.
unplug hdmi cable, reconnect with the supplied video cable and press standby/on and REWIND button together.
Have a try.
Hi, I tried the second suggestion first and it worked!
Thank you so much for your reply
It's a great DVD player that I didn't want to turf!
