Salvatore
I pulled a pluggable RTC module due to a dead battery (internal) hoping to
be able to replace same.
I was able to remove the cover but the package had the soldered on
crystal, caps and battery completely encapsulated in dense and abundant
black material.
I managed to separate most of it and can replace the battery with a more
current cell. The crystal is still embedded in potting material and
cannot be removed to view without destroying the IC.
In the process of de encapsulating, one of the oscillator components
crumbled. It is a ceramic disk (typical yellow) and there is no marking
remaining. I need to know the value of this cap to resolve the issue.
The IC is a VIA VT82885N 24 pin DIP package
the crystal connects to 2 Xtal input pins.
each pin has a capacitor wired to it and they form a junction which
connects to Batt minus. I am fairly sure of this wiring.
One cap is a 10 (line under) and the other is virtually identical in size,
but destroyed. I am not sure about the 10 value being mmf or nf, or ??
Is it common to form this arrangement using identical values.
should either be neg temp coeff caps??
The caps are about 3/16" dia and thin.
SO: Is the circuit as I see it correct?? What should the cap values be??
Thanks for any suggestions (other than tossing the MoBo)
black material.
