Hello all, I am working with a 2n7000 N-channel MOSFET and not getting the desired effect. I was expecting to use the fet to switch power to the rest of my circuit at 3VDC. I checked the data sheet and it says that my typical VGS(th) is 2.1 so at 3VDC I should be able to saturate the gate allowing the flow between Drain and Source to occur. When I connect the circuit as shown below by itself, no other circuit involved, with switch off, I get Vcc as expected between the arrows, but when S1 is closed, I only get ~2.1VDC between the arrows? I checked the RDS(on) and its about 1.8Ω so I didn't think that it should play much of a factor, what am I missing?
Platforms
Content
