I recently came across a couple of old LED signs made back around 1990 by Cybernetic Data Products. These went by the name "Silent Radio." Unfortunately, the ones I have did not come with the power supply module. I think earlier models had the complete power supply built in and you just plugged in a standard AC cord to power it up, but mine have a 5 pin DIN connector on the back instead. I took the circuit boards out of the case and found that 5 pin DIN connector mounted on a circuit board that appears to be the power interface for the rest of the sign.
I made a schematic drawing of this board in order to figure out what voltages are needed at the 5 pin DIN connector in order to bring the sign to life.
I'm pretty sure the drawing is accurate, but I'm not understanding all that I am seeing there.
So - in the upper left of the drawing is P1, the 5 pin DIN where power comes in. On the right is a 5 pin connector that connects to the remainder of the LED sign. The TL072 op amp specs say that VCC is normally +/- 15 volts, so looks like pin 2 on P1 should be -15 volts and pin 4 of P1 should be +15 volts.
Pin 4 of P1 also connects to the input of a 5 volt voltage regulator, so that 5 volt output appears on pin 5 of P2. Pin 1 and 3 of P1 are ground, so that just leaves pin 5 to figure out. I don't really see what is going on with the two op amps and the TIP121 power transistor. Can someone help me figure this out so I can build an appropriate power supply to feed P1 please?
Maybe someone out there actually has one of these power supplies and can tell me about it?
Many thanks in advance!
