Hi there
I'm hoping someone can help me please!
I am building a custom motorcycle which is based on a ducati motorcycle.
The indicator/turn signals on the Ducati have a permanent live feed with the relay providing a pulsed negative contact when switched on (hope that makes sense!). I am trying to fit a Yamaha rear light with integrated rear indicator/turn signals. The problem is that Yamaha work the opposite to the Ducati, the indicator/turn signals have a permanent negative with the relay providing a pulsed positive feed when switched on.
The Yamaha rear tail light/brake stop light and indicators all have a shared earth/negative so I can not make any changes to the permanent negative feed to the indicator/turn signals. The ducati relay is built in to the dash so I can not make any changes there either!
My question is - is there a simple circuit or relay that I can add that would allow me to switch the polarity somehow?? to make this set up work?
I hope I have explained this well, if not I can hopefully answer any questions!!
Thanks in advance
Stuart
Thanks in advance
Stuart
