I have what I think is a varistor. About a 5mm diameter disk, burnt
around the upper edge. It is marked with the manufacturer(?) - CVN
Mexico - on one side and the other side marked
x60
X010
This may not be a varistor, maybe a capacitor or ?. It is in series
with a 15 ohm resistor feeding a relay coil marked 24VAC. The relay
coil burnt out as well as the resistor and this component. Any idea
what it is? Below is a layout of the circuit.
+VAC --------varistor(?)----15 ohm res.-----switch------24vac relay
coil-------ground
x60
X010
coil-------ground
