Hey there,
I'm trying to hook up an RC module to open collector outputs and am stuck, any help would be greatly appreciated
The RC module has 4 buttons. I soldered 4 wires, once to each of the buttons, plus a 5th wire to a common terminal.
I can successfully "press" any of the 4 buttons by shorting the buttons wire to the 5th one. When I test it with the multimeter I see that the 5th "common" wire is +12v, and the wire to the button is the ground. So, I have 4 "grounds", that I can short with the 5th +12v common wire.
I'm trying to connect these wires directly to some open collector outputs on a PC interface card. The interface card has a common ground, and the outputs turn on/off.
I think everything would work correctly if the 5th wire for the buttons was ground instead of +12v (and the 4 wires soldered to the buttons were +12v instead of ground). But, hooking up the 5th wire to "ground" on the PC interface card, and the 4 button wires to 4 open collector outputs, this doesn't work
I'm very new to electronics, so I'm kindof stuck here. I hope I explained this correctly, can someone shed light on what I need to do, so that the PC interface card can "press" these buttons with it's open collector outputs?
Thanks,
Mike
Thanks,
Mike
