Help with circuit
Hi guys!
hi need help before i ruin everything.
I'm thinking of building a small sound box. this is how I intend to do it.
an adafruit FX board has a pre-recorded sound that I can loop with a button. Instead of a speaker directly, I want to take the signal through a voice changer (velleman mk171 voice changer) to be able to change the sound.
it is possible? Taking the signal from adafruit and plugging in that mic would have been on the voice changer? then an amplifier before the speaker.
Hello,
Have a look at this:
Bertus
Hi Bertus, thank you!
Having some trubbel understanding, pretty new to reading diagrams. Any how, so i think i understand some of it. Remove the parts you red markt replace it with a pot meter. Så the left and right channel going from the FX board to the pot meter. Than what? Where do I connect the pot meter on the voice changer? Thank you so much for taking time with a noob
bertus
Hello,
The crossed parts are for powering the microphone and the microphone itself.
You can remove tiose parts and connect the middle pin of the potmeter to where the microphone was connected.
Bertus
Okey, thanks. I think i got it.
How about the potmeter, what happens if i turn i all the way around? How should I think about that... And why a potmeter instead of a fix'd resistor? :)
bertus
Hello,
The potmeter can be seen as an adjustable attenuator.
The signal from the FX board is likely to high for the MK171 board and needs to be attenuated.
Bertus
