Hi everybody
I had 3000 watt power inverter for a while now input 12V through 200 Ah lead acid battery output 240V 50 Hz, I use the inverter to power up my apartment during the planned blackouts in my country, few days ago I burned out the inverter when I introduced the mains power to the outlet of the inverter while it was on, I got all the kinds of bangs and flashes, before shut down the power switch. When I opened the inverter I found that the nearest MOSFET was blown out as in the picture.
When I flipped the board I found a 16 pin SMD IC burned as well as seen in the picture.
What is amazing that all the part numbers were deliberately erased by the manufacturer, I will try to find the part number of the MOSFET but what I need help with is the IC, I thing its some kind of oscillator because its connected to the Gats of the MOSFETS.
Can you help me to identify that IC
