Help With A Little Drone/Camera Project
Hi! I am trying to make a remote controlled camera to attach to the bottom of my drone. What I want is a control on my drone remote, that allows me to control the tilt of the camera. So i can make it look straight down and straight ahead and anywhere in between.
So what I need to be able to do is have some way of slowly spinning a motor on the drone - by remote control. The motor and circuit have to be quite small, and weigh under 20 grams ideally (don't know if that is possible). Also, it has to have quite a large range, around 10-50 meters.
Can anyone direct me to where I can buy remote control motors, or help me at all? I'm quite new to electronics and stuff like that, so I may need a bit more detail/guidance.
Thanks!
A pan tilt device for FPV is available on Ebay as well as others, already supplied with a pair of mini servos for around $6.00.
https://www.ebay.com.au/itm/PT-Pan-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Either control pan/tilt via spare rc channel of get a bit more adventurous and look at making your own head tracker.
Free one open source on the internet .....
https://www.rcgroups.com/forums/sho...-Headtracker-(Easy-build-No-drift-OpenSource)
Guess it depends how much experience you have with electronics.
