Hello,
New to the forum and my first post !
I am trying to build the circuit in the last picture. Aim is to turn on and off the led in a alternating way on each press of the button.
Circuit seems to be working on this video:
and also when I replicated it on tinkercad. However, for some reason no success on the breadboard. I must be doing something silly but no success after a lengthy troubleshooting.
The problem is that, on the first press of the button, led goes on, however subsequent presses does not turn it off. All R/C values are triple checked. I've also observed the voltage on pins 2/6. As expected voltage stays stable at 2.5V (Vcc=5V) when there is no button action. First press actually creates a spike down to 0V, as expected again, and led turns on. However, when I press the button again, next voltage spike only goes upto 3.01V (not enough to hit the threshold of 2/3Vcc (3.3V) to turn to led off again.
In a desperate attempt I tried different C values, but peak always goes up to 3V. Also tried to change R1 to raise Vstable towards 3.1V it didn't help (perhaps was a bad idea).
1 - What would you recommend as the next step of troubleshooting ?
2 - If you are patient enough, can you see an issue with my breadboard setup ?
3 - Any other ideas to fix it ?
Many thanks,
Charles
Many thanks,
Charles
