Please show a drawing of what you did...
A picture is worth a thousand words
Can you measure voltages with a DVM?
Ok! I've made some top notch drawings!!
And yes i can measure voltages with a DVM if by that you mean a digital multimeter. I have some Uni-T UT71. I've been doing it. But i don't trust myself measuring Amps. I know how to do it but i rather no because it's easier to not know what i am doing and damage something.
I've been testing (moon shooting actually) some different things in the meanwhile and i'll explain each one of them by drawings. I'll call them scenarios.
Please consider that powering the LED like you taught me works with no problems.
This is the first scenario. For this little guy i have Current ratings for typical and max consumption. 20mA is for idle and 55mA is typical load. This is the 555 device i had that i was using before your transistor solution.
Since 20mA for idle is about the same as the LED switch light i thought at least i could have some response from the device replacing the led that i can make work with the transistor for the circuit board.
Failed! Even if i did manage to do it i used Falstad's circuit simulator and i with realised that i won't be able to give more than about 30mA to the collector because base voltage is too low. Am i right? Also used this calculator: http://www.petervis.com/GCSE_Design...ator/transistor_base_resistor_calculator.html
For 55mA of Icolector i would need to replace my R1 for 68.66ohm resistor. Then i would go to falstad's simulator and the thing did not got as i expected, Ic was never higher than 29mA.
Scenario2:
The manual for this one doesn't talk about amp consumption. I would really like to use this device because i can trigger it with delay.
If i turn the hotspot manually on at the same time that charging starts taking place, it won't boot and it go in to charging mode. So for all of this to work nicely it should be: first i turn the hotspot on via switch. 1,8v is present, starts the p8015(device above) that's programmed to delay triggering via relay for the charging device in the amount of time i want, say 10 seconds. When i power the hotspot off, 1,8v stops being present and the p8015 goes off, and so the charger.
It didn't work. and since there's that diode bridge on the input i think that ground doesn't behave like ground on the socket i was plugging in.
I guess this board should need more amps than the previous scenario, so i quickly gave up and thought of another thing:
Scn3:
So i would only need to trigger it and i should be fine to accomplish what i need. This is my preferred solution because i don't have to worry about powering requirements from the device. But not so easy as it seems
I used the DVM on the "pushbutton" socket and where on i wrote +11v on the drawing it's actually not very accurate as sometimes it reads about +10v, and i've probed with the DVM´s negative lead on the other pushbutton socket. I figured i could make the transistor sink that current but i didn't manage to trigger it. Don't know why!
scn4 on the desperate side:
well this guy is rather small and i searched the datasheet online. Couldn't be sure that the data was for this exact brand but i guess ratings should be similar and i suppose it needs 37,5mA for activation. more than what i guess i have according to my simulations.
i was trying to replicate this :
which is everywhere on the internet and seems so easy when you google "drive a relay through a transistor"
I guess my transistor is ok because i re-tested it with the switch's LED light and it still works like the first time.
Sorry for the ultra long post and many many thanks for your time again.
