Help - Voltage Check on Cushman CE-3 Monitor
Norb Sauvage
I recently bought a Cushman CE-3 Communications Monitor that had a
zapped fuse on one of the three power supplies behind the left hand
plug in. It had a leaky electrolytic that I replaced, and now
everything is OK with the fuse, but the unit is not working properly.
The three supply voltages measure +37.25, +13.28, and the one ith the
fuse problem +0.50. If someone has a service manual or a unit that
they can check would you let me know if those voltages are in the
ballpark. I also, could use a Service/Operations manual for the unit.
Norb K7MRU
