Ricky said:
Forgot to include a question, but you answered it. Are you saying that
I could use a small transformer as a current sensor? If I hook-up a
fuel injector in parallel to a probe using a tiny transformer, I could
get a current reading?
My intention is to see the difference in current when my Honda runs
rich and when it runs lean. I`d thought maybe I could see a higher
voltage produced when it runs rich.
The first thing to do is decide WHAT you want to measure.
I don't know how fuel injectors work, but they MIGHT work by modulating
the WIDTH of the driving pulse rather than its amplitude. In that case,
you don't need to measure current at all. In fact, the average current
will be influenced by factors other than the amount of fuel dispensed
and lead you to wrong conclusions.
Measure the width of the voltage pulse. Use a voltage probe and a
scope. Heck, you might even be able to use an old dwell meter, but that
will be rpm influenced.
If you really need a current measurement and it is pulsed, you can get
the AC component with a transformer. Start with a split-core ferrite
with some turns as a secondary and clamp it on the injector wire.
that should give you a relative indication of the peak current. If you
want the shape, you need a lot more "equalization circuitry"
Shunt the secondary with the smallest resistor that will let you get
a reading on your scope. Lower resistance -> better low frequency response.
If the clamp-on probe from your timing light unplugs, you can also use that.
Again, making calibrated measurements and looking at AC current
waveforms is hard. DC is lots harder.
Making relative peak measurements on AC currents is not so hard.
Not measuring current at all...priceless...
mike
Bunch of stuff For Sale and Wanted at the link below.
laptops and parts Test Equipment
4in/400Wout ham linear amp.
Honda CB-125S
400cc Dirt Bike 2003 miles $550
Color LCD overhead projector
Tek 2465 $800, ham radio, 30pS pulser
Tektronix Concept Books, spot welding head...
http://www.geocities.com/SiliconValley/Monitor/4710/
