Hi, I have this DeWalt string trimmer with a big brushless motor and 40V power supply. It quit working over the summer. When I opened it the windings were discoloured and burned. I thought I would make an attempt at re-winding the motor. Well I have.
Now it stutters but does not turn. Where did I go wrong? I have a few guesses to lead the way. Can somebody help me connect the dots. I did some research and wired it in delta fashion as it was originally. I'm reasonably sure I have the pairs of poles done right. There are 6 poles with 23 wraps each.
first guess: I miss counted on some of the wraps and don't have exactly 23 wraps on each pole. My guess here is that the motor would still turn but not efficiently or maybe with less power than intended. Correct me if I'm wrong.
second guess: I have some of the poles wrapped in the wrong polarity. I was not sure if I should be winding all poles clockwise or all anti clockwise or if I should alternate poles. I'm not even sure if this matters. I tried to find an answer to this question before I started winding but could not find anything. Most likely this is the fault. If so can somebody clue me in on the proper way to do this.
