Yes, you could put it that way, & there's 40.2V (AC) between yellow & orange. Yellow & orange each alternates between being + & - since a transformer deals with AC.
I did show you a rough calculation of it, but to be sure about the maximum allowable voltage level please get the transformer's regulation spec's from the supplier.
A higher VA transformer means better regulation, and less sag when "cranking it up".
A higher voltage will mean better "punch". Of course it also places a little higher demands on the cooling. I was not able to see from the pic's if that might be marginal.
Clearly the original transformer was the weakest link, failing before the amps & the drivers. It's hard to guess what's "next in line" but I'd guess the drivers are.
Since the manuf. claims it's a 200W system I'd expect it to have a 250VA transformer, but you have shown the drivers to amount to only 94W so 120VA "should suffice".
On the other hand there's a "rule" stating that an amplifier really should be able to handle so-&-so much more than the speakers, to be able to deliver unclipped music.
Clipping amp's produces higher frequency harmonics which are more detrimental to speakers than if they had been supplied with the unclipped higher-power burst instead.
This is where the "as-high-as-possible" power supply voltage comes in handy. 25V is cutting it close but I don't think 22V is; unless the regulation is worse than expected.
Toroids have better regulation than ordinary square transformers do btw.
Whether the solid foundation of a possibly excessive powered transformer is a waste of money will depend on your feelings, situation, & nationality, but I won't get into that.
You'll have to decide whether this is a repair or an upgrade or whatever. I wouldn't hesitate to use a 22V 250VA transformer, costing perhaps just a little more than a 200VA.
Do you have a multimeter btw.? Would you also be able to get real numbers of the mains voltage variations in your area throughout the year from your mains supplier?
