Help re-plumbing an air compressor.
amdx
Hi all,
My dad gave me an air compressor many years ago, at some point, one
of the tubes from the compressor to the tank broke. I had another so, I
ignored it. It has sat for years and parts have scattered. It seems like
this would be obvious, but I don't know to put this back together. I
find one open male connection going to the tank and two
male connections on the compressor, one larger than the other.
The shut off switch and the pop off valve are intact as are a valve on
the tank and a valve to adjust output pressure.
I just can't make sense of two connections to the compressor and one
to the tank.
Any Ideas?
Sanford Manufacturing
Model 104A200-22
22 Gallon Tank
2 hp motor
Thanks, Mikek
Maynard A. Philbrook Jr.
Hi all,
to the tank.
Any Ideas?
Model 104A200-22
22 Gallon Tank
2 hp motor
Thanks, Mikek
I assume you have one that turns off when pressure has reached its set
point? There should be a pressure switch on the tank.
you have an inlet and a outlet on the compressor.. there should be a
arrow to mark the direction that compressor turns. If you are not sure,
start it up so see which way the motor turns.
The inlet should have some kind of filter on it. if you put your figure
over what you think is the inlet and then hand spin the pump
in the correct direction, it should create vacuum (inlet) and the other
should create pressure (outlet)
Outlet most likely goes to the tank or into the pressure switch which
goes to the tank.
Inlet needs a filter on it.
Etc..
Jamie
amdx
point? There should be a pressure switch on the tank. Yes, it is in place.
Now that you have sent the picture you probably see the the two
tubing connections where 81 and 82 attach. and the air intake on the
opposite side.
Ya, that's no problem, easy to tell the inlet from the out. But it still
has two connections to the compressor besides the intake.
goes to the tank.
Etc..
Jamie
Thanks much, Mikek
amdx
Thanks for the picture, wish it had little better detail.
I'll study it a while, my dad modified it with a third gauge,
which makes things different, but if I need to, I'll go back to
original and work from there.
Thanks, Mikek
I have powered the motor and I find both of the connections
on the compressor have air pumped out. I think the center, larger
fitting is the main outlet to fill the tank. I don't understand the
second and the drawing doesn't help, because where it goes, I don't see
anything for it to attach to. There's nothing behind the pressure switch
as shown.
Mikek
amdx
Thanks, Mikek
After some investigation, I think I have a handle on it.
It has become clear parts have been changed.
I probably need to buy some new parts.
I found this picture:
http://tinyurl.com/mwb2dfl
Which show where the tubes land. But there is no landing for the small tube.
And then I looked up the pressure switch.
http://tinyurl.com/lx95566
This shows where the second smaller tube will land.
Thanks, Mikek
N_Cook
Hi all,
to the tank.
Any Ideas?
Model 104A200-22
22 Gallon Tank
2 hp motor
Thanks, Mikek
Is there a way to test that the over-pressure pressure release mechanism
is not seized/corroded shut and a bomb in the making?
amdx
I need to purchase a new pressure regulator, the one on it is not the
correct type. The unit has on over pressure valve. After $50 is removed
from my wallet it will work as designed.
This is actually boat related. I acquired ownership of a pontoon
platform. One corner is low in the water, I started pumping air into the
pontoon yesterday with a small air compressor and didn't see much
movement, so I decided to get out this bigger compressor and started
trying to make it work.
This morning, using the small air compressor, I saw bubbles that I
missed yesterday. There is a 4" x 7" plate at the front of one pontoon
that leaks. Today I will remove the plate and pump the water out. The
goal is to get it out of the water and home.
Thanks, Mikek
Jerry Peters
as shown.
Mikek
The smaller tube is probably for the head pressure relief. When the
pressure switch turns off, it presses a pin on a small valve which
relieves the pressure in the compressor so it can restart without
overloading or stalling the motor.
Tom Miller
It is called an unloader.
amdx
Ahhh, that's making sense, I could not understand why there were two
inputs to the pressure switch. Now I understand.
Jon has mentioned a check valve, where does this go in the pneumatic
circuit?
amdx
The standard scheme is there is a check valve at the tank.
Hi Jon,
Where does the check valve go in the pneumatic circuit?
The pressure
switch has two ports, one to sense, and the other to relieve
pressure in the compressor line so the compressor doesn't stall
the motor. The small port on the compressor head would be this connection.
So, if you don't have a relieving-type pressure switch, there is no place
to connect the relief port. But, a relieving pressure switch is
a REALLY good idea, it makes the motor's job a lot easier.
When it is working right, you will get a big PFFFT every time the
switch turns the compressor off.If it keeps hissing, then the check
valve is gummed up or jammed.
Jon
Looks like I'll be ordering a new pressure regulator and check valve.
I need to check the diagram and see where the check valve is supposed to
be, I don't think there is one.
Thanks, Mikek
Tom Miller
amdx said:
Hi Jon,
The pressure
Thanks, Mikek
There must be a check valve or the unloader would empty the tank. It is
usually located in the inlet to the tank. The compressor output goes to a T
connector then to the check valve. The center of the T goes to the unloader.
The pressure switch connects to the tank directly.
Sometimes all this is integrated into the pressure switch.
amdx
I'm still having a problem.
I ordered a new pressure switch,
http://www.amazon.com/Pressure-switch-compressor-95-125-unloader/dp/B00273UQQQ/ref=pd_sim_hi_2
I have plumbed and wired it.
As I said before, the compressor has two outlets, one 3/8" and a smaller
one 1/4". The larger I connected to the tank, the smaller goes to the
unloader on the pressure switch.
The motor will start and then shortly the circuit breaker pops.
The air intake does has air coming out in puffs.
My next step will be opening the unloader tube to see if the
compressor will keep running. ( I think i might) but I don't know what
that means. I'll also change outlets, maybe I just have a weak breaker,
but I doubt it.
Later today, I'll take some pictures, maybe someone can see what I've
done wrong.
Thanks for you suggestions, Mikek
amdx
but I doubt it.
done wrong.
Here's a picture of my plumbing job,
http://s395.photobucket.com/user/Qmavam/media/CompressorTubing_zps2292e455.jpg.html
I did unhook the small tube going to the unloader and the compressor
will run fine. It does not have the air puffing out of the air intake as
before with the unloader tube connected.
I doesn't fill up the tank either, I suspect because all the air is
coming out the unloader tube.
Any ideas?
Thanks, Mikek
Tom Miller
I did unhook the small tube going to the unloader and the compressor will
run fine. It does not have the air puffing out of the air intake as before
Any ideas?
Thanks, Mikek
Where is the check valve? How many connections does the tank have? Where
does the pressure switch connect to the tank?
Shaun
"amdx" wrote in message
Hi all,
to the tank.
Any Ideas?
Model 104A200-22
22 Gallon Tank
2 hp motor
Thanks, Mikek
Just go buy a new one, that is a small air compressor - not worth bothering
with
Shaun
Jerry Peters
Any ideas?
Thanks, Mikek
You do have the check valve connected in the right direction?
amdx
I have found the problem. Half of the check valve is part of a
manifold. The manifold should hold a spring to push the ball against
the seat. No Spring!
Thanks, Mikek
